Help with venting for toilet + sink + washer
Mosho
Toronto
Hello! I'm finishing my basement and after the drains were set up I decided to expand the bathroom and more the vanity to the opposite wall. Now I need to both add a drain for the vanity sink and also connect the pipe to the vent. The toilet is also vented through this pipe. Since the walls are already spray foamed I'd prefer changing as little as possible while achieving the drains and vents I need.
Another issue I have is that the vanity sink rough in will be about 26'' from the finishing floor level. Is that too high?
Blue - existing
Green - needed
Would something like this work? Thanks!
John Gayewski
Iowa
You can't drain a washing machine into your toilet vent is that what you are doing now?
Mosho
Toronto
Yeah, that's how it was set up by my plumber before the new slab was poured (underpinned the basement), but it was also inspected by the city
John Gayewski
Iowa
Well its wrong you can't add to it because it's already wrong.
John Gayewski
Iowa
Wet venting is for bathroom fixtures. Or 1 or 2 dfu fixtures.
The washing machine displaces too much air in a drainage system to reliably vent a toilet.
Mosho
Toronto
I see. Would it help if I had the 2 inch pipe reduce to 1.5 from the end of the wet vent to the machine? I'll talk to someone here about that, there's a floor drain nearby but I'd have to cut the slab to have a separate drain. Another option would be a utility sink, and have the washer drain into that?
John Gayewski
Iowa
That won't help.
Youd be best to use the toilet vent as a drain for the lavatory, then cut into the building drain for the washer. Better to have the washer tie in far away from a floor drain or any other fixture branch.
Mosho
Toronto
That won't help.
That makes sense but there's no way I can tear up the length of the entire slab to do that...
Mosho
Toronto
They do have pumps for washing machines. You could pump it into your drainage system elsewhere.
The main vertical stack for the upstairs bathroom is 15-20ft away through all the studs around the bathroom, could I do it that way?
John Gayewski
Iowa
Yeah of course you just need the right pump for a laundry. About any pump will do that.
