While drain after toilet was not needed (if that is what the combo is), no harm in having it.Thanks for the feedback, I did in fact forget the vent take off between shower and wc on bath 2 (first photo.). Got that in there now.
How'd you do the under-slab dry vent take off? 2" wye rolled up 45 degrees above horizontal, then turning the vent back horizontal just below the bottom of the slab, to run to a wall, where you turn up with a LT 90?Thanks for the feedback, I did in fact forget the vent take off between shower and wc on bath 2 (first photo.). Got that in there now.
Yes both vents are 2”.How'd you do the under-slab dry vent take off? 2" wye rolled up 45 degrees above horizontal, then turning the vent back horizontal just below the bottom of the slab, to run to a wall, where you turn up with a LT 90?
Maybe too late now, but an alternative is to wet vent the WC and the bathtub from the lav in Bath 2 like you did in Bath 1. You wouldn't have to change much, just move the kitchen tie in a bit further downstream to make room for moving the toilet tie-in to downstream of the lav.
And just to double check, your Bath 1 lav and Bath 2 shower vent (or lav if it's your only vent) are both 2"?
Cheers, Wayne
Leave it the way it is.View attachment 67319 In looking at this again, could I skip the parallel 2” drain by adding a vent take off upstream of the shower, and then have the 2” kitchen sink drain enter the 3” upstream of that? Then tie the two vents together above the flood rim of the kitchen sink?
Once the kitchen drain comes in, you can't do any more horizontal wet venting. So if you want to wet vent the WC and the shower via the lav, the kitchen drain has to come in downstream of all the bathroom fixtures.In looking at this again, could I skip the parallel 2” drain by adding a vent take off upstream of the shower, and then have the 2” kitchen sink drain enter the 3” upstream of that? Then tie the two vents together above the flood rim of the kitchen sink?
https://www.pvcfittingsonline.com/pipe/schedule-40-pvc-pipe.html?size_in_inches=26Anywhere I can find 5" PVC?
Does the plumbing code have a separation requirement between the building drain and the water lines?Between the two ‘risers’ I will run the pex down under the slab, in the same trench as drain pipe.
There's something to be said for a manifold on the hot water side. If hot water draws are intermittent, then the tepid water to empty from a home run 1/2" line is less than a 3/4" trunk plus a 1/2" branch.I thought about doing a small manifold for each zone with home runs to the fixtures.
I would say yes. 3/4" PEX is only a little bigger inside than 5/8" copper.Any benefit running 1” supply from meter?
Had you opted for stainless steel clamps instead of copper rings, one tool could have done the 1/2, 3/4 and 1 inch.Got a crimper on order
The only separation requirements I've been able to find in UPC is 1501.12 but those are alternate water sources for not potable applications. 312 and 314 mention trenches but nothing about separation. Also just to be clear this is the "interior trench" if you will, inside the building perimeter. The exterior sewer and water line trenches are about 15' away from each other.Does the plumbing code have a separation requirement between the building drain and the water lines?
Do you want a hose bibb in the back? Any irrigation? If your lateral is 1", then it would make sense to continue the 1" to either of those.
Cheers, Wayne
Sorry I should have said clamper not crimper... the stainless clamp model is indeed the one I ordered.Had you opted for stainless steel clamps instead of copper rings, one tool could have done the 1/2, 3/4 and 1 inch.
