I'm building a house (my first!) and will be doing the plumbing (among other trades). You all were so helpful making my first plumbing project a success so thought I'd try my luck a second time.
It's a relatively simple ~1152 sq ft, one story, 2 bed 2 bath in Austin Texas. Slab foundation into which I soon need to place the plumbing. All will be inspected and we're on 2015 UPC.
See proposed layout below. 4" line coming in from outside, will be sleeve going through foundation grade beam sleeved in a section of 6" pvc.
Bath 1: 4" off the main line going to wc, flange set 12-13" off 2x6 wall. 2" line coming off to shower drain, serving to wet vent wc. 2" p trap for shower drain set in ~12x12x12 box filled with sand during slab pour. 2" line coming off to lav drain, serving to went vent shower. Vent continues up and out roof, or maybe out sidewall (and then up to roof, outside building.). Upturned wyes for all these wet vent connections.
Washer: 2" off main line, 2" running up to AAV, 2" trap, 2" standpipe up into one of those wall box thingies.
Bath 2: 4" off main line. Sanitee connecting to lav, then up to vent for lav. 4" line continues to wc, flange as described above. 4" line continues past, with 2" coming off to serve tub. Again p-trap in 12x12x12 box so I can wiggle that around. 2" vent up, connects up with lav vent, heads out the roof.
Kitchen: as drawn, 2" sink drain runs ~4' and drains into 2" shower vent, but I'm feeling like maybe that's not allowed?
Any comments? Apart from measure and remeasure 10x, any other slab specific stuff? So far I've got sleeve through foundation wall and a few wraps of sill plate foam where pipe comes through slab.
Will have some pex/water line questions eventually but would love to get the dwv side sorted out first. Thanks in advance!
Jeff
Jeff
