Hello folks,
I am switching from in ground well to a large above ground water tank to supply a home. The existing well pump is submersible which I will replace with a sta-rite SNE-L shallow well pump which comes with a pressure switch attached. I also have a typical pressure tank that has its own T and pressure switch attached that controlled the submersible well. My question is, is one of the switches now redundant? Which pressure switch should control the new pump? I'd assume the one attached to the sta-rite pump. If so, what should I replace the pressure switch on the tank manifold T with? Just a typical brass plug, I guess?
Thanks for any help. Amateur guy just trying to save the farm
