Hello, I am attempting to install a toilet and join to an existing drain under a concrete slab. Where the existing drain is located, I have limited space to work in a corner of the existing bathroom (In the picture, the lefthand wall is a vanity that will be removed, I will have plenty of space for the toilet after). I have already cut the existing 3" drain and spliced in the combination wye with pipe stubs and fernco fittings.
Is this an acceptable setup to for a toilet drain? Would you recommend a more appropriate setup?
Under each of the fernco fittings, there is an approximate 1/4" gap at the splice. Is this amount of gap between the existing drain and splice acceptable, or should I fabricate a new one? I am a DIY homeowner and any information would be very much appreciated. Thank you.
