My bathroom sink doesn't drain properly without "burping it". The odd part is - the sink seemed to drain fine the first few years we lived here, but now it doesn't. I have taken apart the piping to check for clogs or otherwise obvious issues and all is clear. The Toilet & Tub/Shower both drain just fine.
A few weeks ago, in an attempt to correct this issue, I replaced the under cabinet piping arrangement with what is pictured below (mainly to add an air admittance valve similar to what had been used under our kitchen sink). The original under-lavatory piping was previously a simple trap then went straight down through floor. Yes, i wasn't keen on using the flex/accordian adapter, but it seemed the only means i could find to connect the riser plumbing to the pipe coming up through floor.
Any suggestions/advice would be greatly appreciated!
