Hi everybody!
Can someone kindly look over these load calculations? This is my first time doing this and I'd like feedback.
Unit #1
220.12 General Lighting
220.42 Lighting Load Feeder Demand Factors
220.54 Electric Clothes Dryers
220.55 Electric Ranges--Dwelling Units
220.51 Largest of Fixed electric space heating loads or A/C load:
220.21 Non-coincident Loads
220.53 Appliance load--Dwelling Units
220.53 Appliance load--Dwelling Units (75% Total Appliance Demand Load) = 2,457.00 va
220.50 Motor Loads @ 120 Volts
TOTAL CALCULATED DEMAND LOAD in Volt-amperes = 34,215 va
TOTAL CALCULATED DEMAND LOAD in AMPS @ 1 Phase 3 Wire, 120/ 240 Volts = 143 Amps
MINIMUM SERVICE REQUIRED = 143 AMPS
SERVICE SIZE REQUEST = 150 Amps for Unit #1
Unit #2
Total Motor Demand Load = 945 va
TOTAL CALCULATED DEMAND LOAD in Volt-amperes = 29,734 va
TOTAL CALCULATED DEMAND LOAD in AMPS @ 1 Phase 3 Wire, 120/ 240 Volts = 124 Amps
MINIMUM SERVICE REQUIRED = 125 AMPS
SERVICE SIZE REQUEST = 125 Amps for Unit #2
These calculations are for two units in a building that has 200 amp service for the entire building. I asked for the electricity to be split between the two units. Initially, I requested two 125 amp panels to be installed in each unit (but instead got two 100 amp panels). However from these load calculations, I believe Unit #1 needs a 150 amp breaker panel, not 125 amp and Unit # 2 is ok with the 125 amps.
Should the electrician have done these 2 load calculations in order to determine the correct panel size for each unit? Am I correct that these calculations can be used to determine the units' panel size? Am I also correct that Units 1 & 2 require 150 amp & 125 amp panels, respectively?
Electricity's kinda fun...
Thanks for your help.
Cub
Unit #1
3va/ft^2 of floor area, including unused space adaptable for future use
Floor Area= 1582 ft^2 = 4,746 va
220.52(A) Small Appliance LoadFloor Area= 1582 ft^2 = 4,746 va
1500 va for each 20 amp branch circuit required per 210.1(C)(1) in EACH kitchen, pantry, breakfast
room, dining room, or similar areas
# of Small Appliance Branch Circuits = 3 X 1500 va = 4,500 va
220.52(B) Laundry Load room, dining room, or similar areas
# of Laundry Branch Circuits = 1 X 1500 va = 1,500 va
Total General Lighting & Appliance Load = 10,746 va220.42 Lighting Load Feeder Demand Factors
First 3000 or less at 100% = 3,000 va
From 3001 to 120,000 at 35% = 2,711 va
Remainder over 120,000 at 25% = 0 va
Total Lighting Demand Load = 5,711 vaFrom 3001 to 120,000 at 35% = 2,711 va
Dryer #1, Greater of Nameplate KW rating or 5kw = 7.20 kw = 7,200.00 w
Electric Range Nameplate KW = 10.00 kw = 10,000 w
Fixed Electric Space Heat #1 - w A/C#1 = 43.0 MCA@208-240V
Total Non-coincident Load = 7,632 va220.53 Appliance load--Dwelling Units
Qty Description va (watts)
1 Dishwasher(s) = 1200
1 Microwave(s) = 1100
1 Refrigerator(s) = 350
1 Rinnai Gas H2O Heater = 76
1 Stand Alone Ice Maker = 550
Total Connected Appliance Load = 3,276.00 va1 Dishwasher(s) = 1200
Qty Description Amps
1 Garbage Disposal(s) = 8.1
Total Motor Load = 972 va1 Garbage Disposal(s) = 8.1
430.24 25% of Largest Motor Load = 243 va
Total Motor Demand Load = 1,215 vaTOTAL CALCULATED DEMAND LOAD in Volt-amperes = 34,215 va
Unit #2
Floor Area= 500 ft^2 = 1,500 va
220.52(A) Small Appliance LoadFloor Area= 500 ft^2 = 1,500 va
# of Small Appliance Branch Circuits = 2 X 1500 va = 3,000 va
# of Laundry Branch Circuits = 1 X 1500va = 1,500 va
Total General Lighting & Appliance Load = 6,000 va220.42 Lighting Load Feeder Demand Factors
First 3000 or less at 100% 3,000 va
From 3001 to 120,000 at 35% = 1,050 va
Total Lighting Demand Load = 4,050 vaFrom 3001 to 120,000 at 35% = 1,050 va
Dryer #1, Greater of Nameplate KW rating or 5kw= 7.20 kw = 7,200 w
Electric Cooktop Nameplate KW= 2.00 kw = 2,000 w
Fixed Electric Space Heat #1 - w A/C#1 = 13.4 MCA@208-240V
Total Non-coincident Load = 3,216 va220.53 Appliance load--Dwelling Units
Qty Description va(watts) Qty Description va (watts)
1 Dishwasher(s) = 1100 w
1 Freezer(s) = 300 w
1 Microwave(s) = 1000 w
1 ECO 11 Water Heater(s) = 13680 w (240v * 57a)
Total Connected Appliance Load = 16,430 va
220.53 Appliance load--Dwelling Units (75% Total Appliance Demand Load) = 12,323 va1 Dishwasher(s) = 1100 w
Qty Description Amps Qty Description Amps
1 Garbage Disposal(s) 6.3
Total Motor Load = 756 va
430.24 25% of Largest Motor Load = 189 va1 Garbage Disposal(s) 6.3
Cub
