Help with Hot Water/Recirculation System Plumbing Design - New Residential Construction
abc123puck
Hi,
My wife and I are working with an local architect group here in South Florida on a new home for our family. The home is approximately 5500 sq ft under air and will be on well water and a septic system. One ask I had of the engineers/architects was to try to a utilize heat pump water heater (HPWH) in the garage to help with energy efficiency and to provide some slight cooling/dehumidification for the space. We also valued somewhat timely delivery of hot water while limiting significant water waste, so I understood a recirculating system would likely be recommended. I understand HPWH aren't ideal for recirculating systems due to the ambient pipe heat losses (although the hot water and recirc piping will be insulated) and the demand placed on the heat pump, but I am willing to work around that by utilizing some smart controls on the recirculation pump (e.g., timer, temp control, etc.) and making sure the HPWH(s) are oversized if anything.
With that background, we received the attached plumbing design from the MEP engineers and I am trying to wrap my head around their hot water and dedicated recirculation design. My understanding is that the MEP firm has largely worked on commercial or multi-unit residential in the past to provide some perspective. The HPWH spec'd by the MEP is a single 80 gallon Rheem ProTerra unit. While I am not a plumber or MEP engineer, I have spent significant time trying to understand best practices for design of a recirculating system and am struggling with the complexity of this trunk and branch system and how appropriate balancing among the branches would occur. I wonder if limiting the dedicated recirc line to the two main trunks (presumably connected to the furthestmost point on each trunk) would simplify things both from a balancing and cost perspective while still providing hot water to fixtures in a somewhat timely manner. In addition, I feel that a single 80 gallon HPWH is undersized and wonder how a second unit would impact the most logical design for the system (e.g., separate loops entirely vs 2x units in parallel, etc.).
Here is a link to the plumbing design and home schematic if the attached images aren't high enough quality to see the details.
Any thoughts would truly be appreciated. Thank you in advance for you help.
abc123puck
Bump. Any help would be appreciated. I am just looking to see if my concerns are valid or not. Depending on that I may hire a plumbing consultant to help going forward, in addition to reapproaching the MEP group with my comments. Thanks
xedos
Georgia
Curious how you ended up resolving this design ???
My thoughts are:
-one 80gal tank is no where near adequate for that size house.
- I’d drop the central hot line going to the outdoor bar. Get an undersink elect. on demand unit. Less waste and no wait for a very low demand location.
- are you going to have a pool heater ? Propane, heatpump, solar ?
abc123puck
My thoughts are:
We did remove the hot water line going to the outdoor bar area, just going to use cold water there. As for the recirc, it remains a fight with the MEP engineer so trying to get this resolved another way with the plumbing contractor directly. We were able to get the MEP to add a note that a 2nd HPWH tank could be added. As for pool, plan is for a heat pump heater/chiller.
