tobinator
I have a long downhill run from my utility room to a lawn hydrant. Buried run is about 150' long (3/4" black poly)and there is an elevation drop of at least 32'. As any plumber would guess, there is a severe water hammer in the house when there is any action on the hydrant below.
There's a shut-off valve before 3/4" Copper exits the stem wall below grade, then a 90° bend and a transition to poly. Mostly closing the valve reduces the hammer, but at the expense of flow.
Pipes in the utility room are well secured
Downhill run is pretty straight (and would be tough to change)
Water pressure in house is 50/70 PSI (pump) I shudder (get it?) to think what it is at the hydrant.
Single family well
I was thinking about a big 18" home-made hammer arrestor right after the 90° in 3/4" galvanized with a schraeder valve on the cap so I can recharge it every summer. Only about 6" of pipe would be above grade and it could be well secured to the stem wall and a straight line to the hydrant.
Any thoughts about a remedy?
How about the best way and some easier ways?
BTW, I did consult my plumber as he was retro-ing the house and before the ditch was finished. He made no mention of water hammer. Of course he also forgot to sweat a bunch of fittings, cut 3/4 through three consecutive floor joists and bailed out before his work was done, so I guess I'm not too surprised... I had to finish the project because the other contractors wanted to start over and I was almost out of money. So much for taking the lowest bid.
Thanks in advance!
Matt
Single family well
Thanks in advance!
Matt
