ShannonChuy
Okay so my washing machine is overflowing the standpipe when it drains, it was doing this a while ago and then it stopped but now it's doing it again. The washing machine is on the main floor in the middle of the house (it is supposed to be for a stackable but my dryer is in the basement), the drain pipe runs probably 20-25 ft until it reaches the main stack. It's a 1 1/2" pipe with no other fixtures plumbed into it. There is no vent on this line, and no vents near it to tie into (everything else vents through the main stack but they're much closer). Standpipe is probably about three feet high and is connected to a 90 which immediately goes into the p-trap (these connections are under the main floor in the basement). I've tried snaking the drain and didn't find any obstructions. I do not believe this plumbing was done by a licensed plumber and I can't figure out how to fix this. Do I need to change the drain to 2"? Can the standpipe act as the vent? Or is the whole thing a giant headache? I'm in Massachusetts and am unsure of the current code.
