HELP Water Meter Red Triangle
Austin Petersen
Lakeland Florida
Good morning everyone! I had a slab leak 2 months ago and just recently had a whole house repipe completed 2 days ago. Ever since the leak I have been obsessed with the red triangle (leak indicator). What I have noticed is it doesn't actively spin when everything is turned off in the house, which is good. But every 10-15 minutes I check the triangle and notice it has moved JUST slightly to the left. Maybe a 1/4 or 1/2 of a turn. Then another 20 minutes will pass and it either turns back to the right or it will move another 1/4 of a turn. What does this mean? Is it just pressure since its new pipes or is there a very very tiny leak. Again, it doesn't actively spin when everything is off.
Austin Petersen
Lakeland Florida
You could check the long hand if you are going away for a while. That would average out any bidirectional stuff. If that moves, you could look to a toilet flapper leak, ice maker drawing water, softener dripping from its drain, slow irrigation leak. I am wondering if that arrow going to the right couldn't be going to the left a little more so it looked as if had gone a bit to the right.
Many, if not most, water meters have a check valve that prevents water backing up to the water mains. In that case, a WH heating could still cause some movement if the P&T valve lets some water out, and that gets replenished through the meter after a little cooling. So your action item would be to detect any water coming out of your WH T+P drain after using a lot of hot water, and then stopping using water.
Also, I am curious. What was the piping that needed to be replaced? Copper in slab, galvanized, or what?
Austin Petersen
Lakeland Florida
Thank you for your response. The long hand does not move at all, it's just the small triangle that slightly moves 1/2 turn or 1/4 turn or so.
The piping that needed replacing was copper under the slab. They repiped the house using PEX A pipes and ran the new pipes threw the attics and down into the bathrooms, kitchen, etc. The water pressure is so much better!
Austin Petersen
Lakeland Florida
