We have moved to our newly built house and one of the toilets never flushes correctly. It seemed to do so at the very beginning but not anymore. After flushing, there is constantly a water reflux and it goes down VEEEREEERRYYYY slowly. It helps if I use the plunger but quickly the problem comes back. The plumber says the problem is the manhole that is not correctly donw, but after having opened it, we have realised that there's stuff being blocked before getting to the manhole. We realized this by flushing and using the plunger and seeing that all the poo-poo and paper was slowly coming down.
Is there something blocked on the way? Are the pipes placed too steep? Is it an air vent problem? How can I check the different things? Will I need to break the tiles and replace tubing?
Thank you very much for your help!
Joana
Joana
