Well, as a novice DIYer I think I may have officially bitten off more than I can chew. However, I'm not quite ready to throw in the towel. My current problem is this: I was attempted to tie in a shower drain into an existing drain line under a nearby utility sink. I realize this probably isn't ideal, but this is the way is was set up before and worked well. The reason I'm having to redo it, is that my new shower pan is about 3 inches lower than the previous one, so the existing tee is now too high. So, I cut into the drainage pipe leading into the floor to insert a new tee before redoing all the PVC stuff just above it. In order to do that, I had to dig up a bit of concrete around the metal pipe to get low enough to properly attach the fitting. I was planning on using a flexible rubber T for this. However, once the concrete was removed I discovered the existing metal pipe was LOOSE! Digging a bit deaper, to my horror, I discovered the previous homeowner had simply tore up some concrete, dropped a metal 1 1/2 pipe over a hole he cut into the main 4'' drainage line and morted around it. Now I want to do this properly, but I'm at wits end about how to property tie into the cast iron drainage line. I initially thought a saddle T would to the trick, but a newer floor drain installed a few inches away was attached with a flexible T and causing me to now not have enough room to the right of the hole for the saddle. This would have also caused the 1 1/2 new pipe to be offcenter, but I guess that isn't too much of a concern at this point.
A million thanks in advance for any advise on what the correct way to do this would be.
-Nate
-Nate
