saabturbodrivr
Hello,
I have a leak coming from what appears to be a broken solder joint on the output (return?) pipe that leaves one end of an upstairs bedroom heating convector. These are monoflow hot water recessed convectors.
I tried to turn off the valve on the convector...it does not seem to work.
It's 20 degrees out, turning off the water to the heating system is not an option.
It is leaking into the wall below...the ceiling in the covered porch below is full of water/ice. It is cantilevered out ever so slightly from the first floor wall, but I'm still worried it will travel into there.
My heating company won't come for an emergency that is a "plumbing issue". All stores seem to be closed...if I can find a store open, is there any product I can put on that broken joint, while it is wet and leaking, that will actually work? I have had no luck getting in touch with a plumber tonight...that will have to wait until tomorrow it seems.
Thanks for any advice you can give!!!
Alex
Alex
