Charp
I changed the pressure switch from an old pumptrol to a merrill, eliminated a receptacle that was wired in a single gang box on the side of the control box. That receptacle was only hot when the pump was running. I didn't realize that the new pressure switch has 3 postions, auto-start-off. The old one just auto and off. I could hear the contacts when flipping the switch from off to auto and back but off. Once I figured it out and went to start the pump started and switched to auto I had water. Problem is that I could smell something burning. Pulled the control box cover and the visible lug on the run capacitor, between the capacitor and circuit board is glowing while the pump is running. The control box is an old Red Jacket with a relay, start and run capacitor. All I know about the pump is from a 12 year old receipt from a defunct well company that says 10LS10 1 HP SUB. The diagram under the cover says the run capacitor is optional. Is there a possibility of bypassing it? How do I safely pull the capacitor, test it and clean the connections? What Franklin box should I get for this pump? There are 3 wires going into the control box from the well head.
