Simple_Jack
Hey everyone, I did all of the reading on here I could before my brain got full and I have to ask questions.
Well is drilled to 440ft with a refresh rate of 7.5gpm from the bottom, static water is at 155ft. From the well to the house I have 340ft of 1-1/4” poly with no elevation change where I have a CSV and 10 gallon pressure tank. Water usage should never exceed the refresh rate, it’s just me and my wife in a 2 bedroom house with no irrigation. I think I want to set the pump at 300’ if the poly can handle it.
Not sure what all to calculate into the back pressure to size the poly (psi and diameter) and the pump.
What all do I add together?
300’ lift to head= 130psi
Does static level add any psi?
Pressure switch= 60psi
340ft run= psi?
CSV= 60psi?
Would a 5gpm 1hp with 300ft of 1” 250psi poly work? Or am I thinking about the math wrong and need something like 1-1/4” poly with 7gpm and switch to 3/4hp? I’d like to use a 2 wire pump to save on the copper going down and the simplicity of not needing a control box. Either way I should still be fine with the storage I’ll have in the well never running dry.
I guess once I know my total psi I can then look at the pump curves to know the answer to what I asked above.
With brands, are Grundfos and Goulds going to last the longest for the money? Or would a stainless Hallmark be a good choice too? Is there a clear winner in todays market for longevity?
340ft run= psi?
CSV= 60psi?
