Anh Dang
Hi,
I finished building a new house recently and wants to put in a water softener to protect it. I have been lurking this forum for 10 months while the house was building but still couldn't figure out how to select a dependable system that meets my needs.
My house is 3000 sq ft, 3.5 baths (2 shower heads in master), 2 adults but my relatives may move in so possible (5 adults, 3 kids).
I'm planning on having whole house filtration with Homemaster Two Stage + Water Softener
and a Point of Use RO system under the sink.
Edit: The main valve is plastic 1". There is no plumbing loop or open drain so I have to put those in.
Here is my city water report:
Chloride (ppm) 65.3
Iron (ppb) ND
Manganese (ppb) 4.47
pH 8.65
Calcium (ppm) 60.7
Magnesium (ppm) 4.47
Total Hardness [as CaCO3] (ppm) 191
I used the calculator on AWFilters.com and it said I should use a dual-tank 64k grain with Fleck 9100SXT. So I am looking at one of their systems with purolite resin. Are their meters genuine Fleck devices? Is a service flow rate of 10 GPM and peak 15 GPM adequate? Is that the correct capacity?
I appreciate any advice on this. The information on water softener system is confusing. Thank you so much.
Chloride (ppm) 65.3
Iron (ppb) ND
pH 8.65
Calcium (ppm) 60.7
