HELP! PVC fitting leaking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by greatdeals_007, Feb 18, 2020.
  1. greatdeals_007
    greatdeals_007 New Member
    Jan 13, 2019
    California
    I replaced some PVC piping outside to the spigot. however one of the fittings is leaking. I don't have room to cut out the pipe and replace.
    any suggestions on how I can fix this?
    looking for permanent solution.
  2. Terry
    Aug 17, 2004
    If you don't have room, cut back to where you do have room. PVC pipe and fittings don't cost much anyway. Make sure you pick up enough fittings at the store.
  4. greatdeals_007
    Jan 13, 2019
    California
    I don't have room to cut back. is there another way to repair that leaking fitting? is it possible to cut the 1" pvc pipe and how do I get it out of the existing fitting?
Similar Threads: HELP fitting
Plumbing Forum, Professional & DIY Advice Resolved: Help needed with compression fittings Nov 13, 2019
Plumbing Forum, Professional & DIY Advice Need help identifying a brass PEX fitting Sep 11, 2018
Plumbing Forum, Professional & DIY Advice Need help with broken fitting to pressure tank Dec 5, 2017
Plumbing Forum, Professional & DIY Advice Dripping PEX fittings. Help Dec 2, 2017
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
