nphengsiar
Hi. Hope someone can help me. New to the forum. I have a Wellmate SP-9 Air/Water Pressure tank. It has been waterlogging on me for a few years now. Initially, it was every quarter, then every month, then every two weeks, and now every other day. I would drain the tank and then recharge before turning the power back on so the pump comes on. I don't know why it keeps waterlogging. It's supposedly a sealed unit, but I noticed a few weeks ago that there was a grey plug like a gasket plug on a car's oil pan underneath the cap on top of the tank. It was leaking very little air through the plug. I thought that was the reason that it was waterlogging. So, I saran wrapped it tightly using rubberbands. Doing so seem to keep the air from escaping. Well, I thought maybe it would solve the waterlogging issue. But, it didn't. It waterlogged two days later. So, now I don't know what could be causing it to do so. It doesn't have a micronizer. I was thinking of buying one instead of having a service company come out to check the bleeder and spend so much money for them to dig it up and risk not being the issue. Even if the bleeder is no longer working, can't I just have a micronizer installed to fix it? Would the tank need to be replaced? I replaced the air volume float control on the side port as it needed to be replaced. Wasn't working correctly. I just need it to work for until 2019 since we are getting city water as part of the city's plan at that time. Any insights would greatly be appreciated. I'm hoping not to have to spend 1000 or so dollars to fix it knowing that city water is coming in 2019 and that's going to cause a lot out of pocket. Thank you.
