Hi everyone..new 2000sq foot house build. Considering purchasing nice lot with low yield well drilled in 2003....1gpm. I have full report here summarized and would like to ask a couple questions if I may...
Specs:
800 ft depth.
51 foot 6 inch PL casing
open hole (no screen)
grouted with cement
Well log:
0 til 48 feet soil
48 til 800 feet Med Hard Grey Rock
- 94 feet is checked under the column "water bearing"
Pumping test:
Hours pumped: 6
pumping rate: 1gpm
H20 level before pumping 22'
level when pumping 406'
Questions if I may....
1) I understand a deeper well (800) has more storage but isn't that dependent on where the groundwater is in the well? Do I conclude that I have storage from 406 (level when pumping) to 800....or 94 until 800 since 94 is the level noted as "water bearing"?
2)Since this is an open hole well (presume because rock was hit at 48 feet) and only 50 foot casing....how do I calculate storage in the non-cased rock...would it still be 6 inch diameter and calculate at the same formula as if it were actually cased?
3) That 406 ' level when pumping...is that the draw down level (406-22) and does that seem high?
4)Any thoughts from any experts how they would feel about the well and what specific tests they would test for as part of the contract.
...I know this is a lot of info...thanks very much for your time. I am a well newbie...
WALLACE
Specs:
800 ft depth.
grouted with cement
Well log:
0 til 48 feet soil
Pumping test:
Hours pumped: 6
pumping rate: 1gpm
WALLACE
