Lois Lane
We came home from work and neither the hot or cold water was running to the kitchen and laundry room. Water pipes to kitchen continue to laundry room. Everything was working fine this morning. All other taps working fine tonight except kitchen and laundry room. No evidence of leaks. No deep freeze. Pipes replaced 1989, copper. House built 1958, mostly copper, but some iron pipes remain. Had the main shut off valve turned off three days ago when we had a major leak, which turned out to be toilet wax ring failure, now repaired. Not the aerator (I wish!). No valves shut off while we were at work. The garbage disposal did not turn on this morning, but started again after tuning the motor with the little allen wrench they give you. Garbage disposal worked perfectly last night. Three household problems in three days is more than I can handle!
