QC91
Hi, need Help in picking replacement Central HVAC system for our house the Square footage of the home is 1,990, and the zip code is 94520 for our climate we get 80, 90, and low 100 degrees in the summer, in the winter we get upper 30 to 40 degrees at night our home doesn't have good insulation in attic but did have newer dual pane windows with low e glass, our current HVAC system is Rheem from 1972 or 1973 the Natural Gas Furnace Model number 3010 125 HDA input is 125,000 BTU, and the Bonnet is 100,000BTU the outside condenser Model number is AT42B1 not sure if that is 4 Ton unit, also seeing that the new HVAC system are so much more Efficient would we need smaller system? I was looking at Different ones we will have HVAC contractor install it but wanted to do some research I found this one Rheem 95% 98,000 BTU 2 Stage Furnace + 4 Ton 15.1 SEER A/C on Ebay item number 182163860369 http://www.ebay.com/itm/Rheem-95-98...860369?hash=item2a69cfeb91:g:vysAAOSwKrhVccJH
any help would be appreciated
