Installing a water softener, including re-piping from the meter onward. I am trying to figure out what type of connectors are here before trying to uncouple everything. To the left of the gray-ish oxidized base under the black plastic part of the meter, there is a brass or cast copper nut which I think is threaded onto the gray-ish base. Out the other side of the nut is a brass nipple-like pipe. I cannot tell if there are threads on the end of the nipple-thing that enters the nut.
Is that some form of union? Do couplers come as just a nut? There's that tiny little hole in one of the hex-sides of the nut.
I'm wondering how much I can safely remove. That brass-ish pipe nipple has a ton of pipe wrench-like groove impressions in the part, and it is slightly out of round. I'm worried that might be a sign someone else tried to remove it, and couldn't.
Thank you for any insight.
