Help Identifying Kohler 3-Handle Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by BikeNHV, Oct 17, 2017.
  1. BikeNHV
    BikeNHV New Member
    Feb 28, 2017
    New Haven, CT
    Hi All,
    I have a Kohler 3-handle faucet that I think could use a rebuild. It will drip quite a bit into the tub when the diverter is set to shower and the water is on. To prevent dripping when the water is off, the valves need to be closed very, very tight. This was a rental for a long time and people clearly did not care to do this, so the tub is actually pitted due to this leak over the years.
    I found a bunch of rebuild kits here, but none seems to match the look of my handles. Unfortunately I don't know the age or model. 1872 house, obviously not original.
    http://lincolnproducts.com/catalogs/bath-sink-repair/index.html
    Ignore the cracked tile and crappy caulk job, that will be addressed when I deal with the faucet.
    [​IMG]
  2. Smythers
    Smythers New Member
    Oct 11, 2017
    Ontario
    (couldn't get that link to load up on my end)
    If I read you correctly, you want to fix the leaks from the faucets and diverter. What I would do is take out one or both of the cartridges and the diverter valve stem then head on down to the local plumbing supplier or big box store. Kohler's got replacement parts out that will cover your old 1870's plumbing :)
    http://www.homedepot.com/b/Plumbing...pair-Cartridges-Stems/KOHLER/N-5yc1vZcf5nZ1qh
    Hope that helps.
  4. BikeNHV
    BikeNHV New Member
    Feb 28, 2017
    New Haven, CT
    Yup, that's correct. I'm assuming that I'll be replacing all 3 stems, which is fine.
    I was just hoping to identify it and buy parts in advance, as opposed to taking it apart and trying to match the parts. Less downtime of the shower (especially if there is a risk that parts aren't in stock).
  5. hj
    It uses Valvet stem/cartridges for the hot and cold sides.
  6. BikeNHV
    BikeNHV New Member
    Feb 28, 2017
    New Haven, CT
    Thank you. I have a few great supply houses nearby so I will check with them to see if they have the genuine Kohler parts, before I rip the faucet apart.
  7. hj
    1-800-4KOHLER for the parts.
  8. Master Plumber Mark
    Master Plumber Mark Sensitivity trainer and plumber of mens souls
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    You would be wise to change out the faucet....
    if you are going to mess with the tile anyway,
    I would advise you to just to change it....
    I probably have those parts buried in a bin somewhere but have
    not used any of them for over 30 years. mostly because they are trouble
    and half the time I made the problem worse with the new parts
    good luck
  9. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    I admire folks who want to recondition old faucets. I also ask: why and what for?
    Looking at your picture, I would recommend a new faucet and replacement of the broken tiles, for a low budget fix job.
    If you have some more funds, gut the tiles to the studs...I can only imagine what you'll find...and start anew.
    If you are handy, you can turn this to a very nice bathroom without spending a fortune. And if you run into obstacles you can't handle, you can always ask here for help.
  10. BikeNHV
    BikeNHV New Member
    Feb 28, 2017
    New Haven, CT
    It's a thought. And it may happen regardless within a year or so. But I was looking for a quick fix with minimal downtime due to higher priority projects underway - in the process of building an entire kitchen from scratch (in an addition).
    I just renovated the rest of the bathroom. Sink+plumbing, toilet, new floor tile, full rewire, fixtures, shower door, etc.
    I expect that some of the plumbing may be brass, not copper, which I'm not experienced with. Had to call in help for the sink replacement for the same reason. That wall cavity is open underneath in the basement (typical old house thing, wall was added after since the house was built without bathrooms), I don't see any signs of water damage in there.
Similar Threads: Help Identifying
Shower & Bathtub Forum & Blog Valley, Help Identifying shower valve Jan 29, 2019
Shower & Bathtub Forum & Blog Mixet, Help Identifying Shower Control Knob Jan 23, 2019
Shower & Bathtub Forum & Blog Help identifying two handle valve Jan 21, 2019
Shower & Bathtub Forum & Blog Help needed identifying 3 handle shower diverter stem Dec 25, 2018
Shower & Bathtub Forum & Blog Fiat Shower Pan / Drain Leaking - Need help identifying model and repair advice Dec 8, 2018
