Help identifying brand to find parts.
Gary Parker
Louisiana
Our house is well over 50 years old, yet unsure if the faucets in the tub are that old. This is a picture of the stem on the cold side and a pic of the barrel. Have a drip issue and expect new parts may fix. I am not a plumber, so any help would be appreciated!
Gary Parker
Louisiana
Sorry, it's basically just got one hump of grey plastic that determines the extent of which the knob will turn. I don't have it apart right now or I would take a pic. But was told on another forum that it was Delta...but after looking at the parts for them, I noticed they show a spring, which I have yet to see in what I have unless it is inside barrel behind the seating rubber for which the stem seals. Still looking for answers, so thanks for your reply and any help is good.
The SHAPE of the top is what is important, but it is not likely to be a Delta. The spring is under the rubber seal. Valley also has a spring but its parts are different from Deltas, although they LOOK "similar".
Gary Parker
Louisiana
Thank you so much for your time replying to my post. I took the knob back off and without taking stem out, this is the top as it sits. It is still working, but not probably not for long. I actually took a heat gun to the plastic to pry it back level on the end and gooped it with Vaseline to help seal. Hope this helps more in identification.
it has all the characteristics of a Valley II stem, but your photo is still not from the best angle. A photo of it OUT of the faucet would be better.
Gary Parker
Louisiana
Thanks again, after reading your reply I looked at some Valley II parts, and indeed they look identical except no brass. But I expected that in this day and time. What would I need tool wise to take this apart completely to get at spring and replace the seat rubber? Any tips or tricks will appreciated.
You ust stick something into the rubber seat and pull it, and the spring, out. The spring will come with a white plastic insert with instructions as to WHICH side of the spring goes downwards.
Gary Parker
Louisiana
Thanks and even though I am working nights and should be asleep, I have been studying online both Delta and Valley parts. and you are right, they very similar. I found a pic with the nut style that is on my faucet and it seems very close....only thing is, I can't see anymore views and don't know exactly what brand or part number is being shown. But if I was a guessing man, would say this is the closest thing I have found that would replace what I have.
Cacher_Chick
Test, Don't Guess!
When I cannot identify components, I take them to the plumbing supply store where there are good illustrated catalogs and parts on hand to match up.
