kingoflondon
I had a new bathroom installed two years ago. Was a decent job, I was happy with the quality of most the work that was done. However...
The bathtub (which is also a shower stall) leaked. We established that the caulk had failed and when my wife takes her ridiculously long shower, water would seep through the side of the bath and we were getting damp patches on the ceiling below.
The contractor re-caulked. Was ok for a bit, then failed again.
I then recaulked myself. Was ok for a bit, then failed again.
I then tried using epoxy grout. Was ok for a bit, then failed again because the grout split in half.
I have caulked plenty of tubs before without any problem, I am relatively competent at doing this. I'm being very sure to remove all old caulk, clean properly, applying when bone dry, leaving a couple of days to set. I am applying the caulk with the bathtub filled with water so it's at its lowest.
The problem is the bath. It is pretty big, and when it's full of water, the bath is dropping maybe 3/4mm and this is causing the caulk/epoxy grout to fail.
What can I do! I see a product which is an adhesive caulk strip which seems like it might fit the bill, but the reviews are terrible as it comes unstuck easily. Perhaps if I used the strip and literally caulked it to the tub and wall perhaps? Would rather not have to remove the epoxy group, wouldn't even know where to start with that.
Has anyone had this problem before?
