Mark Mallard
I bought a small home with a well that I'm told has not functioned in three months. The pump is a deep water submersible that has only two wires running into the well cap and down to the pump. All pressure switches have been bypassed for testing purposes and two wire 220 hooks up to the two wire input of the very standard control box. (I have measured 220 across the two leads). The control box should have three leads coming from it, all of which must be used for the control box to have any purpose. (The QD control box senses increased current draw on start up and switches on the red lead to power a secondary start winding in the pump... or it should work that way). Nothing connects to the red wire in the control box. Only the two lead providing 220 do the pump on the two wires connect. So, effectively I have 220 coming into the control box and 220 coming out of the control box. Turn on 220 at the breaker and the pump either runs but does not pump, or just hums, I am unable to determine which.
Since I'm told this setup has always been this way and worked for years, and there was never any connection to the red wire, I take it that this pump worked off of 220 and the red wire was either not needed to kick start a secondary start-up winding in a 3 wire pump OR the pump was replaced at some point with a two wire which has the start-up controls built in. So it pumped water before and now it does not. I am told a pump repair guy came by six months ago and did something in the control box as a TEMPORARY fix, which got the pump to start and it worked for three days. I told the person who claims to observed this, that this was IMPOSSIBLE because 220 goes into the control box, 220 comes out of the control box, and without the red lead running to the well, the box does nothing because it cannot carry the capacitor's charge to the pump on startup along the needed red wire. So the person gets the repair guy on the phone and he states that he did, indeed, swap two wires in the box to make the pump start.
So my question is this, to those familiar with the electrical control boxes.... could this guy have somehow temporarily wired the starting capacitor across the two 220 wires, such that the capacitor was used to kick start the run windings? Then maybe turned the pump off, put all back to normal and the pump was then able to start for awhile before once again needing a kick start?
