Help connecting tapered metal drain from cement laundry sink to pvc
Simpson148
Massachusetts
Can someone suggest a good way to connect this tapered metal drain to the PVC pipe?
Would a flexible coupling with clamps work on the metal drain side? If so, how would I connect that to the PVC?
There is a replacement assembly available from Chicago Faucet Shoppe if the drain is not long enough.
Thanks for your thoughts.
