I have a Hellenbrand iron curtain 2 and the aeration tank has a plastic part the water sprays out of to aerate. This gets gunked up and reduces flow and pressure. Anyone come up with a way to flush this out without disassembly? Even then the deposits are very hard to remove. Even a soak in strong iron out solution did not clean it.
Would a full size ‘T’ and drain in the pipe between the tanks flush this out or just be a leak risk?
I do not have a chlorine injection system.
thanks is for your thoughts
