Height of shower p trap
Straight_A
Pennsylvania
New to the forum although I use it frequently for reference. I'm running fixture drains from a bathroom to the main drain stack (about 2 ft to the right of the end of the pic.). My question is about the p trap shown. I have a 2" vertical drain from a shower pan, p-trap, 2" vent then it connects to 3" horizontal drain via a combination wye. Upstream I have waste from vented vanity and vented toilet. Is it permissable to have the bottom of the p trap below the height of the horizontal drain? (Or does the p trap need raised and tied into "2 inch vent/drain via sanitary tee with 2" waste then dropping into 3" horizontal waste line?) I am subject to 2015 IRC. Thanks for the help.
Tuttles Revenge
The way the trap is shown is correct. The new water/waste coming from the shower, pushes or displaces the water already in the trap. The excess waste then becomes higher than the Weir of the trap and begins travelling downstream via gravity. Liquids take the form of the object they occupy and in this instance can never get any higher than that of the weir.
*edit just to add some useless info
The shape and size of a trap also is important. Both are designed to help the trap stay clean by scouring. Too small a diameter and it doesn't drain efficiently. Too large a diameter and the water passes by too slowly and gunks up. Too much angle slows the water. Too deep the waste has time to settle out. Too shallow of a trap and the water that keeps sewer gasses from passing evaporates too quickly.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
The Tee on it's back is incorrect. The fitting should be a combo, and the air flow direction should be sweeping downstream.
The vent need only be 1-1/2".
wwhitney
Berkeley, CA
Agree with the above in practice, but it's worth noting that on "the fitting should be a combo," that doesn't have the strength of code under the IPC. It has no requirement like the UPC that all vent fittings below the fixture flood rim are of a drainage pattern.
And PA uses the IPC.
Cheers, Wayne
I had bad teachers we used to put santee on back routinely or always and never a combi but got set straight a few years in by inspector Mr Whipple city of Long Beach.
I suppose other than santee backwards its ok.
My code calls for tailpiece as short as practical but not over 24 inches (unless some verbiage has been changed) , I could Imagine my old inspector calling me on it or just giving me a hard time . I think a long sweep 90 under vent hole and a 2x1 1/2 x 2 santee pointed toward drain be better than a long tailpiece. but I'm being a bit nit picky
