Hey Roberto. Erik. Question for you guys.
This shower has a Kerdi Line drain. The kind with the square hole grate. I watched the video. I watched two get installed first hand, with the little screwing thinging and everything. What I can not figure out is how can I follow the install rules.
The thin-set show above has to be a good 3/8" thick. What did you do Roberto? Should I cut sliver os tile down maybe as shims???? It looks like they used Ardex 8+9 in the photo for the Kerdi Band. One type of thin-set for the floor tile and maybe a third type to set the grate.
I checked Laticrete's thin-set specs and it says 1/4". Same with 254 and 315. How can I fill the underside of the Kerdi grate with a good 3/8"-1/2" of thin-set.
This is what Schluter wants I think but not what Laticrete says is OK. What should I do?
I'm thinking I might have to go get the tile grate instead of setting so much thin-set almost twice as thick as it's designed right at the drain.
