Hey all!
I need to satisfy my curiosity. I briefly searched the interwebz to no avail.
I used a standard 1/2" square head pipe plug (like below) to plug both shower head outlets while doing my current (never ending) bathroom remodel.
I have no leaks within the system and have periodically checked over the course of the project. I recently finished tiling and grouting the shower area and was ready to put on the shower valve trims. I wanted to check one last time (before I closed things up) that there were no leaks at the shower valve and when I put my hand inside, I noticed that the insulation was wet! I almost sh#t a brick for too many reasons I care to share right now. . .the most important one being that the pipes are not accesible (yet). It wasn't leaking from the shower valve, so I knew the problem was at the shower head drop ear. I was beside myself for about 15 minutes wondering how long this thing has been leaking and then dropping F bombs knowing that I either had to get to work on the access panel (which I didn't have time to do this weekend) or heaven forbid, have to ruin all of my good work by removing tile and Kerdi. . ..
After I calmed down a bit, I for some reason reached up to see if there was anything going on with the plug and it was completely loose!! Not even finger tight!! I checked the plug in the other shower head. . .and the same thing!! Completely loose, although no leaks on that side.
Both plugs were "installed correctly" with Teflon tape, proper torque, etc., and actually re-checked a few times initially. It's not rocket science, right?
I've never seen anything like that happen before. How could those plugs back out like that?? Has anyone ever experienced anything like that?
Tom
Tom
