Hello Irrigation Experts
So after resolving an issue from 2 years ago using a product called "Add a Zone" where the non-working zone is repaired using power from a 2nd working zone (not simultaneous, but alternating... a switch of sorts), I had to add another this season when a different zone/valve box stopped working (see https://terrylove.com/forums/index.php?threads/one-valve-in-zone-not-opening.61555/).
Anyway, today I came home to find "Short" displayed on the LED. The "short" indicator cycles through each zone, one after the other for all 18 zones.
I unplugged the controller (circa 1992-1993), removed/tested/replaced the backup battery; it was nearly dead. Didn't help... It still displays "short" when plugged in or unplugged on battery power, if that means anything. Maybe I need to follow specific instructions to reset? I did not see anything in the "current" manual other than to 'turn dial to Run, Manual-Single Station or Manual-Program Cycle and press "off" button.'
A little background... seemingly unrelated. 2-3 days ago while working on a landscape project, one of the water lines was pulled from a "T" connector. No electrical was involved... The zone worked fine AFTER the line was reattached and presumably the controller was running fine until today. I'm not absolutely certain whether it was yesterday or today when the "short" first posted, but I know it was working after the broken line was reattached.
Any thoughts or instructions to determine the cause would be greatly appreciated.
Thanks,
SBerg
Thanks,
SBerg
