Hard to remove filter cannister... leaks?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mikdoo, Jun 14, 2019.
  1. mikdoo
    mikdoo New Member
    Mar 9, 2019
    Chicagoland
    I put the cannister back on my whole house water filter on handtight. I use some silicon grease on both the threads and the o-ring. Yet it takes a bit force each time I have to remove it to replace the filter. Enough force where I can see the copper pipes shifts.
    Theres a threaded union close by as well as threaded valve and solder joints.
    Im worried that the force of removal could cause a leak at these joints. This setup has been in place for a few years without any leaks.
    How likely is a leak to occur at these joints?
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    You might post a picture. Your filter housing is held up by a pipes only? Maybe you could add some support to the pipes.
    I think most people use a special wrench to turn the sump for removal. That could free up a hand to hold a pipe as you turn.
  4. mikdoo
    mikdoo New Member
    Mar 9, 2019
    Chicagoland
    Thanks I took your advice for added support. Even though it appeared to be adequately supported like any other normal installation, this afternoon I secured it with a split ring hanger and a threaded rod and in another spot with a hanger. Hopefully that will do it... certainly overkill now.
    In general, do these filter heads leak after repeated removal of the cannister? I got copper male adapter in one side of the plastic head and a brass nipple in the other. I used tape on both since I was afraid to dope up the plastic.
    I would ask what else I could do to make it easier to remove but I doubt there is much else I can do. Im already using silicon and only going handtight... and I am not Popeye either.
  5. Reach4
    Sep 25, 2013
    Some dope is OK for plastics.
    The O-rings get replaced, but usually that is when the rubber has expanded lengthwise, and you cannot get the ring back in the groove. If you don't have a replacement o-ring and if you don't have a bypass, you have to go without water for a while.
    What size is your sump (the part that you unscrew), and/or what is the replacement cartridge?
  6. mikdoo
    mikdoo New Member
    Mar 9, 2019
    Chicagoland
    Its one of those basic 20" blue sumps... i think pentec. I do keep plenty of o-rings on hand but I have only changed it once in 6 years! The first o-ring went 5 years then it couldnt get it to seal.
  7. Reach4
    Sep 25, 2013
  8. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    The proper way to unscrew the filter housing is with 2 large wrenches going in counter direction to each other. This way your pipes will be protected and won't twist.
    To avoid a leak when installing a new cartridge, use the 2 wrench method to tighten, hand tight is not tight enough.
    If you have a spare O ring, store it in a zip bag tightly zipped.
Similar Threads: Hard remove
Plumbing Forum, Professional & DIY Advice Hard to remove kitchen faucet Aug 3, 2018
Plumbing Forum, Professional & DIY Advice how hard to remove pop-up drain? Jul 7, 2006
Plumbing Forum, Professional & DIY Advice Tub Surround- Hardi, Redgard, subway tile- Socal- Exterior wall insulation? Sep 1, 2019
Plumbing Forum, Professional & DIY Advice Handy hardware advice on Moen tub/shower repair Jun 8, 2019
Plumbing Forum, Professional & DIY Advice Best Greasy Slimy Goop for Extreme Hard Water - ??? Mar 8, 2019
