Hairline cracks on ABS toilet flange?
index1489
California
I’m replacing a 10 year old toilet that wasn’t leaking on a stainless abs closet flange on the second floor.
Cleaned it up and I noticed some very tiny hairline cracks on the bevel of the abs.
Anyone see anything like this before? I’m debating if I should brush some ABS cement on them before the install.
You should have removed the rag for the photo.
Are you confident that the piece you are talking about is not a remnant of a old horn on your wax ring? Pull the rag and see if that can be pulled out.
index1489
California
It’s 100 percent not a piece of the old horn from the wax ring. It came off in one piece stuck to the bottom of the old toilet.
I took the rag out and took another photo. It looks like actually it might just be a crack in some excess abs cement.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
yes, scrape clean as best you can. Multiple passes. Let set at least partially, then daub again, the more layers the stronger. Should be fine after that.
Never seen such.
