roobinsteen
Hi, glad to be a part of this forum-this is my first post. The main sewer pipe for my house is hung about 5 feet above the basement floor. There is a sink in the basement that is used often. This basement sink has a small sump pump underneath it, which pumps the water up into the ceiling, where it connects to another pipe, and can drain by gravity into the main. Whenever the basement sink pump runs, it causes the sink in the kitchen upstairs to gurgle, sucking the water out of the trap, and releasing bad smells into the kitchen. I do not think that the upstairs pipe that the basement sink pipe connects to has anything else draining into it; only the kitchen sink. How can I remedy this problem? I imagine this is a venting problem. Is there a vent or valve that I should have, but don't? The basement sink pump has what I think is an air admittance valve on top of it. I've attached a few pictures to help make it more clear. I attached 2 pictures of the connection between the pipe coming from the basement sink and the upstairs pipe, 1 picture of where that connects into the main sewer pipe, and 1 more of the valve on top of the pump.
