Jklingel
One of our Toto toilets has a "ring" at the top of the normal water level, and we can't get it out. We have tried CLR, some other mild "bowl cleaner" and a pumice stone. I am hesitant to use muriatic acid, as I don't know if it will take off the Whatever coating on the toilet; it seems there is somewhat conflicting info here when I searched. My questions then are, (1) what is the harshest chemical I can use that won't destroy the slick coating that Toto puts on their toilets, and (2) should we pumice with said chemical sitting on the toilet wall, or pumice after we let the chemical sit and have removed it? We have softened water from a well, and have a septic tank. My plan would be to use some nasty chemical, then suck up what I can, add clean water, and suck that out, too. This only happened in the one toilet in our second bathroom; only two of us in the house and this toilet is used a tad less than the other one. Thank you for the advice. John
