Mikes1098
Our hot water system has a Grundfos comfort UP10-16 recirc pump installed -- with a dedicated return line. The return is plumbed into the cold line going into the hot water heater - which seems ok to me.
However, when the sprinklers go on and the water pressure drops, it seems to get into a vapor lock somehow on the pressure side. The pressure side of the pump (returning to the hot water heater) gets insanely hot, like there is steam in the line... while the suction side is cold. So clearly, no flow. Once I purge the line, everything works fine again.
It seems a bunch of people say to plumb the return into the drain.... including this YouTube video by Grundfos ( at 1:15):
But an equal amount of people are passionately saying that is wrong ..... I too originally felt this was only done because it was easier and not correct. But the YouTube video made me question why they would do that on the new install from the manufacturer.
Does anyone know why installing the return through the drain port would be the recommended configuration? I did notice the pump only has a max of 4 ft of head.... this is very close to the distance to the top of my tank..... not sure if that is why.....
