Grundfos Circulator Pump Noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Nick B, Apr 20, 2018.
  1. Nick B
    Nick B New Member
    Apr 20, 2018
    Hyde Park, NY
    This is my first post, so please be gentle...
    A few days ago I noticed a noise at night when the house was quiet, I finally found it today and it is the circulator pump on my boiler.
    It sounds like a fast chirping. The noise is intermittent, even when the boiler is running. Pitch and frequency change when I adjust the speed setting on the pump. The pump was installed about 2 1/2 years ago, which means that it's probably just a few months out of warranty of course.
    If anyone knows what this noise is, can it just be fixed by doing system adjustments, or should I replace the pump? The heat is working fine, but I've learned that random noises should be dealt with.
    It is a Grundfos UPS15-58FC
Similar Threads: Grundfos Circulator
Plumbing Forum, Professional & DIY Advice Does grundfos make 230v thermostats for hot water recirculator pumps? Jun 22, 2014
Plumbing Forum, Professional & DIY Advice Best GRUNDFOS recirculator pump? Jun 25, 2009
Plumbing Forum, Professional & DIY Advice Alternatives to Grundfos Comfort Valve Feb 1, 2019
Plumbing Forum, Professional & DIY Advice Grundfos booster pump Jun 14, 2018
Plumbing Forum, Professional & DIY Advice Normal Operation of Grundfos CU301 controller? Oct 17, 2017
