Grounding a portable generator
Discussion in 'Electrical Forum discussion & Blog' started by Cubey, Nov 9, 2007.
  1. Cubey
    Cubey New Member
    Aug 10, 2007
    Southern Arkansas
    Wow, you FINALLY answered my question of WHERE the bonding should occur!! AFTER I take my generator apart. I asked you TWICE *where* it would be and you would not answer my question.
    And I already TOLD YOU no one in this piece of crap town will touch a portable generator. I would probably have to drive 2 hours (each way) to MAYBE find someone who would.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    And just what is the drive worth to you, the price of a generator, the price of someone getting hurt or even killed?
    I don't know the style of generator you have and the bonding will take place at a point on the system that the system was designed to be bonded. To try to bond it where you want to may end up costing you a generator so as I have pointed out so many times before, SEEK HELP FROM A COLEMAN DEALERSHIP!!
  3. Cubey
    Cubey New Member
    Aug 10, 2007
    Southern Arkansas
    Thank you for that bit of advice. It somehow never occurred to me to look for a Coleman Powermate recommended shop. I went back to the Powermate site and found a "Service Centers" locater. Turns out there is one locally and the Powermate site says they work on generators, however the shop appears to be closed today (no answer). I will have to probably call back next Wednesday since they will probably be closed until then due to holidays.
    Hopefully it won't cost anymore than $50 to have this done (may have them also inspect/replace the brushes while they're at it) if the place does in fact work on generators like the site says. It would be something if they don't. I will be very upset if they don't. The next nearest is approximately 60 miles but thats still better than 130 miles/2 hours.
    Oh, and reassembling the generator wasn't hard after all. There is just a trick to getting the big metal panel back on due to the hard to get at lock nuts.
Similar Threads: Grounding portable
Electrical Forum discussion & Blog Portable Generator Grounding Nov 3, 2007
Electrical Forum discussion & Blog Grounding to a cold water pipe? May 6, 2020
Electrical Forum discussion & Blog Electrical grounding May 28, 2019
Electrical Forum discussion & Blog Subpanel next to main panel in house - grounding Apr 13, 2019
Electrical Forum discussion & Blog Bonding/grounding consideration for outdoor light on steel mast Feb 4, 2019
