Iron Mann
I have been messing with my system for 4 days (1.5 cu. ft. Greensand with a Fleck 5600 sxt backwashing valve not metered) trying to figure out why i can not get a draw on the potassium permanganate. I have been in contact with the company where I purchased it and checked and re-checked everything. Throat,injector cap, o-rings, back pressure and so on. Finally after removing the Brine valve housing, There are the 2 small ports where the injector ( top ) and the screen ( bottom ) are on the main housing. On the upper opening there is a small part called the Air Disperser It was completely crusted over with Iron. It should pull out with needle nose carefully not to break because it's plastic. I cleaned it and greased the rings and BAM !!! Got a draw. AMAZING Hope this will help someone who is going through the same headache.
I tried to attach a file but it was too large. Look up the Fleck 5600sxt backwashing valve and on the diagram it should still be the same part It is called AIR DISPERSER and it's part # 46 on the diagram. GOOOOD LUCK
