LOL! Please stop reading and believing what you read on the internet.
Most of the higher end equipment has gravel underbedding for many reasons, the cheaper systems often times do not.
Many online companies dont like gravel because of the added shipping weight. Many of these companies are simply trying to save $10 so they can be cheaper than the next guy. I dont have time to write a long list of reasons as to why gravel is used, but I will simply say that we do not ship units without gravel unless it is a vortech tank or if the system has the turbulator which cant have gravel.
Reading through the articale, it is full of bad advice and wrong infromation. I would ignore it. The gravel is used partially to fill the dome portion of the tank and to protect the bottom screen. Even the highest quality bottom screens can fail over time, a gravel bed will almost eliminate that potential. It also allows the resin to be used more efficiently since the resin is completely above the screen, not below it and around it. Another reason for not using gravel is to cheat and use smaller, less expensive tanks, again, another way the low end online resellers try to save a few dollars in their dire effort to be the cheapest guy on the internet. It has gotten very pathetic over the past few years to see how far companies will go to be the cheapest. This is one reason why many manufacturers are no longer allowing their equipment to be sold online.
Their is no negative to using gravel other than the additional shipping weight. And if the screen shifts up an inch, lay the tank on its side slightly, push the manifold back in, wow, that was tough. LOL.
