Goulds J5S squealing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dougq, Sep 16, 2018.
  1. dougq
    dougq New Member
    Mar 4, 2005
    British Columbia
    Hi: I have had this pump on my workbench for a couple of years and wish to make it operational.
    It would squeal after running for a while. I started to take it apart thinking the bearings needed replacing.
    I noted the impeller has been rubbing on the guide vane, which is distorted. Is it possible that is the squealing?
    I could run it on the bench, but I am not sure that would produce accurate results.
    When I spin the motor shaft by hand I can not tell if the bearings are shot, I am used to hearing a rumble from
    automotive bearings if they are bad.
    Any thoughts?
    Thanks
    DougQ
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    A bad bearing is what lets the impeller drag the hub. Remove the impeller and run the motor to see if the bearings make any noise. But bearings are nearly always the problem as they are not grease-able and only have so many hours of life.
  4. dougq
    dougq New Member
    Mar 4, 2005
    British Columbia
    Thanks valveman, I will get it running and hopefully it will be obvious.
    dougQ
  5. dougq
    dougq New Member
    Mar 4, 2005
    British Columbia
    valveman, you were quite right, I could hear a bit of a scraping sound when I ran the motor. I took it apart and sure enough the pump side bearing is shot, I will of course replace both. I have a local supplier for the bearings, but I am not sure the best site online to order the pump seals, any recommendations? The impeller looks ok to me, can I re-use it?
    Thanks
    DougQ
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    What brand and model number pump? I usually get seals from the same local supplier as the bearings? Yes the impeller will probably still be good. See if there is any damage to the eye or hub of the impeller. If not, it will still work.
  7. dougq
    dougq New Member
    Mar 4, 2005
    British Columbia
    Is not the Goulds & J5S all the brand and model?
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
  9. dougq
    dougq New Member
    Mar 4, 2005
    British Columbia
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
    Don't touch the face of the seal halves.
  11. dougq
    dougq New Member
    Mar 4, 2005
    British Columbia
    Valveman: I appreciate all your help, I suspect it will be a few weeks before I get all the parts together.
    DougQ
    valveman likes this.
Similar Threads: Goulds squealing
Pumps and Tanks Well Forum & Blog. Water is life. Issue with Goulds Jet Pump Dec 26, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Goulds pump (with Centripro motor) - no lock washers? Jul 23, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Goulds 10GS15 Submersible Pump Amperage Concern Jun 23, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Goulds GT15 to GT20 May 1, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Goulds water pump GT20 Oct 7, 2017
