Brad Perkins
I am running 2 of the Goulds 10GS05412C pumps. 1 in the well and 1 in my 250 gallon storage tank. Couple days ago my wife said she heard a loud hum from the basement. The water pressure was fine so I didn't get too concerned. When I got home though I noticed the water in my tank was extremely muddy. It rained 2 inches that night so I thought maybe that caused it though only meant I have big problems with my brand new well.
But upon troubleshooting the problem, I decided to let my tank fill up to the overflow point which dumps into a drain so my tank can never flood the basement. I thought I'd let it run all night to see if it cleared up. Then I noticed I could hear what sounded like water was flowing back out of my tank when I shut the well pump off meaning check valve must have failed in a 2 month old pump. Though oddly it seems to be holding ok now. What I believe happened is as the water flowed in reverse siphoning out my tank, it washed sediment off my filter which then ended up back in my tank when the pump kicked back on.
So I got to thinking about this problem and wonder if it really matters. Since my pump dumps into a tank and I have no other check valves in the line, does it matter that the pump check valve is acting up? I would have to cut the pipe in my tank shorter so that water can't ever siphon back out. Then if the valve failed it wouldn't back wash my filter like it's doing today.
Thoughts?
Thoughts?
