Gould J5 deep twin well low pressure
slm91
Hillsboro, OR
I have a setup I inherited from the previous homeowner. Purely used for garden currently. I would like to use it for sprinklers, but the pressure isn't very high (20-30 psi). Is this normal? What kind of pressures should I expect from this setup?
6" diameter well, ~34' well depth, foot valve reaches to approximately 26' deep. Water level is 12' down.
J5 1/2hp Goulds jet pump. Green hose attached to the well was for priming only and shutoff when running the pump.
So maybe you are pumping more than 12 gpm.
slm91
Hillsboro, OR
Used a ~10', 3/4" hose and took about 2 mins 45sec to fill a 5 gallon bucket. So ~1.8 gallons/min. Flow seems to get worse the longer I let it run. Guessing I have an air leak in there.
Also forgot to mention. I did just have the pump rebuilt a few months back as it was leaking water thru a crack in the housing.
slm91
Hillsboro, OR
Ok, found a leak, tightened up and filled a 5 gal bucket in 30sec! So 10 gallons/min.
With flow turned off the pressure doesn't build beyond~25psi. Shouldn't it continue building pressure until the pressure switch shuts the pump off?
Slowly falling pressure with time can be the level of the water dropping.
A clogged jet can keep the pressure from building.
