Good toilet with a 14-inch rough-in?
Eric Albert
I asked my plumber to install the Toto Drake CST744S-12 Sedona Beige/Biscuit EL (elongated) toilet.
When the plumber showed up he said: "Your old toilet has a 14" rough-in; this new toilet has a 12" rough-in. If I install the new one, it'll be several inches from the wall, and, given the age of your bathroom floor, may wobble over time. I'd recommend only using a toilet with a 14" rough-in."
Can someone recommend a good, quiet toilet with a 14" rough-in, preferably in the same price range as the Drake? (I see that Toto has some toilets that can be converted to a 14" rough-in using the UniFit -- does the UniFit work well?)
Sincerely,
Eric
Wow!
Any 12" toilet will work on a 14" rough.
Any bowl can rock, if the floor is uneven.
When a floor is uneven, it should be shimmed, and that is the end of it.
Most 12" toilets will have about 3/4" behind the tank on a 12" rough.
Add two more inches with a 14" rough.
No big deal, it works.
If you want to pull the bowl back two inches, then any Toto with a Unifit will do it.
Other brands use the same bowl as the 12", but use a thicker tank.
Checking the specs on this means that the only thing that changes is the space between the tank. The bowl is still out in the room.
I recommend using a 12" bowl if cost is a factor and space isn't.
If space is an issue, then getting a bowl that can be pulled back 2" is nice.
The Unifit adapter
The skirted toilet design offers the use of a patented modular rough-in system, which has been popular in Asia, called the UniFit Rough-in. The system includes an interchangeable part that replaces the lower half of the trapway, adapting the toilet to either a 10", 12", or 14" rough-in.
Only TOTO uses the Unifit, and only some of their models.
Vespin
Carlyle
Carrollton
Carolina
Lloyd
Pacifica
Soiree
Guinevere
Toto Vespin II CST474CEFG with SS114 Softclose seat.
This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
Installation was by James Love of Love Plumbing & Remodel 206-949-5683
In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
Everything is on the truck for that.
The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
