Lee_Leses
I'm on a ten year quest to find a bath tub that will work well for me!
When I gutted the bathroom ten years ago, I kept the vintage American Standard tub, because I could not find anything that was as good of a size and shape for me. I'm 6'3", and I can completely straighten my legs out in the tub because at the sump (bottom) it measures 46"! I recently measured and looked at the new American Standard Cambridge tub (60 x 32), and that tub is only 41" at the sump. I also looked at a Hydro Systems tub (60 x 32), and that measures 40" at the sump. I do not like this! It's VERY hard to find a more comfortable tub than the original AS tub.
At the time ten year ago, since the finish was worn out and I wanted to change to a biscuit color, I opted to try a bath tub liner. I've had nothing but problems with that, with water getting between the liner and the tub, which of course is a very common problem.
I recently talked to an artist turned bathtub refinisher. He claims he can use some kind of acid to etch / prepare the surface of the original tub to get off all the glossy remaining finish, and use special coatings made by NAPCO in Chicago that according to him is pretty tough and will last for years without peeling.
Does anyone have any experiences with this, to know if anyone makes a 60 x 32 or 60 x 30 tub that is at least 23" wide inside, and at least 46" long at the bottom of the tub (sump).
And does anyone know if it's possible to refinish an old cast iron / porcelain tub in a way that it will last (hold up) for 10 or more years?
Thank You,
Lee
Thank You,
Lee
