Hi, I'm planning to use wall panels for my 48" x 36" corner shower because I like the clean look of a single white panel matched with a white shower pan, as well as the lower maintenance. However, I am a little concerned about how to properly waterproof the wall-wall corner seam?
For the direct to stud kits I have seen, they all have some hardware to connect the panels together but they all still seem to rely primarily on a bead of silicone to waterproof this seam and I am deeply skeptical this will hold up over time. Am I being too paranoid?
For a glue up kit it seems to me that the opportunity is there to use a waterproofing membrane behind the panels. If I used Kerdi I am concerned that the adhesive for the walls would properly bond to it, but I was thinking something like Redguard would work well? Note in this case its really just to waterproof the corner so it probably doesn't need to applied behind the entire walls, but if I was going to do it I probably would just in case
Appreciate any thoughts on how you think this should best be done would be greatly appreciated.
