Sandy T
Hi fellow experts,
Upon in-depth, extensive online search, I decided to ask here since I haven't found the answer I was seeking.
My basement window has a metal sash and frame as shown in the pictures. I want to replace it with a pre-assembled glass block window. In online search, I learned that people used mortar to install a glass block window. But, my window sits on wood, not cement as shown in the pictures.
1. Do I still need to use mortar to install the glass block window or construct adhesive would be sufficient? Are mortar and construct adhesive the same thing?
2. The metal frame seems to be stuck in the cement. Can I just put the glass block window behind the frame and caulk after installation or does the frame need to be removed?
Thank you!
Thank you!
