H.Corning
Hello. I hope you are well today.
I removed our tub spout to soak away encrusted minerals (using a weak acid bath). I've done this before all right.
This time, though, in trying to put the spout back, it doesn't want to line up properly. I can't get it to point downward and be tight up against the wall. It's close, but not quite there. If I keep turning so as to point the outlet downward, it sort of jumps the threads and comes loose.
How do I get it just right, so that the spout points downward and it's firmly seated against the wall?
Thank you.
Thank you.
